Sondre207 Posted September 14, 2021 Report Posted September 14, 2021 Hello, I want to use the horizon in PVGIS (see image), as there is no method of getting that in PVSOL...? Â I was wondering if there was any way to convert .csv or .json -files to .hor that is used in PVSOL? Thank you in advance, your help is much appreciated Quote
developer_mh Posted September 16, 2021 Report Posted September 16, 2021 Hi Sondre207, first of all: The import of PVGIS horizons will be a built-in feature in the upcoming major release, PV*SOL premium 2022 R1, due this autumn/winter. In the meantime you can simply open the exported csv file in Excel or any other spreadsheet software, and add 180 to the azimut values in another column, like so: Â Then you can just copy the azimuth and the elevation column (B and C in this example here), and paste it into the horizon table in PV*SOL: Â Hope that helps, kind regards, Martin Quote
Sondre207 Posted September 21, 2021 Author Report Posted September 21, 2021 Thank you very much! Quote
