Andres Posted June 12, 2021 Report Posted June 12, 2021 Hi, i want to know, how can change the energy to the grid and the comsuption in the Energy flow Graph. instance, just let 80% to comsuption and then 20% to the grid or any option to set up. thanks  Quote
developer_fw Posted June 14, 2021 Report Posted June 14, 2021 Hi Andres, the energy flow graph is painted with the data from the simulation results. It is not possible to set a strict distribution and let the simulation do the rest, since there are many parameters which influence each other. But you could change your input parameters with every simulation to approximate the desired results. Best regards, Frederik Quote
Andres Posted June 15, 2021 Author Report Posted June 15, 2021 ok, thanks you. But if you want to. can you show me, how can change the parameters to let just 80% to comsumption and 20% to the grid? cause, i keep trye to, but i don't get it. thanks  Quote
