Hello. I am working on a project that I created with panels facing in different directions. I can't render the strings as I want with the power optimizer. I want the single string I'm creating to be evenly distributed on both sides. Is it possible? Thank you in advance for your help.
Hi Tayfur,
I assume you are trying to achieve a configuration with separate module areas. Like configuring two separate areas as in this example project:
After placing the modules onto the module areas, change to the tab module configuration. After selecting all the modules you want to configure of this area, right click and choose Add to 'Define Module Areas' Dialog:
Repeat this procedure for all the modules you want to configure. Then all the areas appear in the dialogue Define Module Areas (modules with the hand symbol):
Select all the areas which you want to configure together and follow the usual procedure of choosing a suitable inverter.
I hope this helps, best regards,
