Yash Posted May 27, 2021 Report Posted May 27, 2021 Hello i am making a simulation with with a hybrid inverter battery system . The hybrid inverter i am using is SMILE T-10 from Alpha ESS . When IÂ make the inverter configuration i am also supposed to specify the same as the battery system where as the inverter is supposed to act as a battery system since it is hybrid. When i chose the battery system i have to opt for 4 of hese bateries, where as ideally its just supposed to be one whole unit for a battery and an inverter. any help would be appreciated. athnkyou Yash Bhosale Quote
developer_mh Posted June 8, 2021 Report Posted June 8, 2021 Hi Yash, I think you already did it the right way. When you want to simulate the Smile T-10 (or any other hybrid inverter) in PV*SOL, you have to choose the device as PV inverter and as battery inverter. When choosing the battery system, you have five options to choose from in PV*SOL, since the device is available with five different battery sizes: Hope that helps, kind regards, Martin Quote
