Hello,
I have got problem with my pv-sol project. Program can't generate results (tables, cashflow etc)  and final presentation.
In standard process the calculator should generate all data, graphs, tables etc. Unfortunatelly after calculator process PV-SOL ganerates empty fields in this area ( I see empty fields like not being calculated).
Can I ask for the support to solve this case?
3 hours ago, kornelsoooon said:
Hello,
I have the same issue! It does not show any results as long as I do simulations in 1min steps. Chosing 15min time step, results will be generated - but how accurate are they?
Just before working on this project I made the latest Update to PV*sol 2021 R5!?
Hello kornelsoooon,
hello Georg,
might you be so kind to send me the project files via private message here in the forum? We are bugfixing and would like to verify the fix with more projects.
Thank you very much in advance and best regards,
