Argo Posted May 3, 2021 Report Posted May 3, 2021 Hi. I'm having the problem. I cant import any .obj file on PV SOL premium. While others open this file on their PV Sol premium. Quote
Frido Posted May 3, 2021 Report Posted May 3, 2021 Hi Argo! Can you describe what / where the problem in more detail? Maybe even share your .obj file? Regards, Frido 1 Quote
Argo Posted May 3, 2021 Author Report Posted May 3, 2021 Upload more information scene_mesh_textured.obj PvSol.pdf Quote
Frido Posted May 3, 2021 Report Posted May 3, 2021 Hi Argo! PVSol crashed on me at the first try. Also, when opening your model using MeshLab, I got an Error, but it did open. So I exported your file again as an .obj using MeshLab. This did the trick for me, was able to import no problem. I am unable to attach the file right now, but I am sure you will manage to do justthe same. Hope this helps. Regards, Frido 1 Quote
