Anna_ Posted April 28, 2021 Report Posted April 28, 2021 Hey! I have some question about how to connect all parts of system in case of using Ferroamp components. Lets say: 20 strings with 18 panels each 20 SSO 8kW (1string/SSO) EnergyHub XL Cabinet 112kW (build from 4x28kW) Also I should use DC cabinets between SSO and Energy Hub. When I tried to connect I couldn't get correct results. Probably I am making some mistake that I can't see.  Hope to hear from you soon, Anna Quote
developer_mh Posted June 8, 2021 Report Posted June 8, 2021 Hi Anna, sorry for the late answer. Unfortunately we can't design Ferroamp systems in PV*SOL out of the boy. But it is surely an interesting technology to look at. You could define your own power optimizers in PV*SOL, so that you can connect them as SSO (solar string optimizer, for th other readers) to multiple PV modules. You can then define an PV inverter with the data of the Ferroamp Energy hub, and connect the strings with the power optimizers to it. This would give you good results electrically and energetically. The DC cabinets from your sketch would not be possible to implement electrically, I am afraid. Hope that helps, kind regards, Martin Quote
