Zeira Alford Posted March 25, 2021 Report Posted March 25, 2021 I can't import 3d model file from Sketchup's export. I tried .dae, .stl, .obj,... And got the same error caution. I'm using 31 days trial version of PV*SOL Release 4 2021. Thanks & regards. Quote
developer_fw Posted March 25, 2021 Report Posted March 25, 2021 Hi Zeira Alford, welcome to the forum! At first, have a look at the (probably) same question from yesterday evening for more information why this might happen: Could you reduce the complexity of your model? Is your model a simple model in terms of as few vertices as possible? In case you don't get along, you could send the model via private message, so I could check it. Best regards, Frederik Quote
