Alberto Posted January 27, 2021 Report Posted January 27, 2021 Â The issue is not important from the point of view of energy simulation but it's important from the point of view of economic simulation We are using a real consumption data from the energy meter in 2019. In Spain the network prices are differents for working days and weekends. If we use de 2014 calendar instead of the 2019 the economics calculations are incorrect. It's possible to change it? Quote
developer_mh Posted January 28, 2021 Report Posted January 28, 2021 Hi Alberto, we are aware of the issue, but right now it is not possible to change the simulation year. What you would have to do is the following: 2019 started with a Tuesday, 2014 started with a Wednesday If you import a load profile from 2019, its first day with measurement data is referring to a Tuesday, but you need a Wednesday. So you have to cut the first day of data from the load profile before importing Append this cut out data to the end of the file to fill the year (2014 ends with a Wednesday, 2019 with a Tuesday, so you need one day more at the end - the day you removed from the beginning) Hope that helps, kind regards, Martin Quote
