Majd ELEWI Posted January 21, 2021 Report Posted January 21, 2021 which programs and formats can we transfer to pvsol premium? Â Quote
developer_mh Posted January 21, 2021 Report Posted January 21, 2021 Dear Majd Elewi, there are several areas of PV*SOL premium where you can import data from other programs and in different formats. For example, you can import you own climate data (e.g. from Meteonorm or Meteotest or any other climate data provider). Or you can import your own load profiles (usually in *.csv or *.txt format). In the 3D environment you can import 3D models from nearly any 3D modelling software that exists on the market - we support the following formats: Program / Format Extension Collada (.dae) Blender 3D (.blend) 3ds Max 3DS (.3ds) 3ds Max ASE (.ase) Wavefront Object (.obj) Stanford Polygon Library (.ply) LightWave (.lwo) Stereolithography (.stl) DirectX X (.x) Milkshape 3D (.ms3d) In the 3D environment you can also import any picture (jpg/png/bmp) like floor plans, satellite or drone imagery and so on. I hope this answers your question, kind regards, Martin Quote
Majd ELEWI Posted January 21, 2021 Author Report Posted January 21, 2021 thank you very much. Â Quote
PhD. Huseyin Gunhan Ozcan Posted February 2, 2021 Report Posted February 2, 2021 Dear all, Can we create our own climate data from the experimental studies and transfer to the PVSOL Premium 2016. If it is possible, what is the procedure for this ? Â Quote
developer_mh Posted February 2, 2021 Report Posted February 2, 2021 Hi Huseyin, yes, this is possible. You'll have to create a *.dat file from your measured values (global irradiance, ambient temperature, relative humdity and wind speed), following the format description here: https://help.valentin-software.com/pvsol/2021/en/pages/system-type-climate-and-grid/meteosyn/#options Hope that helps, kind regards, Martin Quote
