power compensation
Hi Alex,
the first point, the feed-in / export tariff is what you get from your utility company for each kWh that you feed into the grid. Using the green plus button on the right, you can define various steps depending on the pv system size in kWp or the energy fed into the grid (kWh).
The second option, the own consumption, is what you get for directly consuming your the energy that you produce with your PV system. Or, in some cases, you have to pay for using your own energy (e.g. in Germany), so there is also the option for entering a fee.
