I have created building 1.  And also configured an inverter and made a string layout for that building.
Houses 1-5 are identical so i copied house nr 1 using the "multiply object" function. 'But this only made copies of the building,and  panel layout. But not the inverter and string layout.
This worked in the previous version of PV sol so please fix this.
Hi Patrik,
Please use the "Copy" function, not the "multiply object" function.
Only in the "Copy" function it can be specified that the configuration should also be copied. This behaviour has always been like this and has not changed.
Best regards
Rainer
