AbiD Posted August 26, 2020 Report Posted August 26, 2020 Hi, I am exported Sketchup model and imported to PVsol. but error is showing like this.How I have to proceed?  Regrads, Abhilash   Quote
developer_fw Posted August 26, 2020 Report Posted August 26, 2020 Hi AbiD, did you check the scaling of your imported model? Is it big enough to place modules onto a surface? If you still run into problems, feel free to send the model via personal message if possible. Best regards, Frederik Quote
developer_fw Posted August 26, 2020 Report Posted August 26, 2020 Hi AbiD, the import is not the problem. You have to draw areas onto your imported 3D-model where PV*SOL is allowed to place PV-modules. This can be done either manually via or automagically via right click onto the model, then edit. After determining the mounting surface automatically you should be able to place modules onto those areas after activating via another right click Don't forget to draw barred areas after activating those newly created areas to avoid placing modules into other objects like chimneys and so on... I hope this helps for starters. Best regards, Frederik P.S.: I did rename the thread since this is no error regarding PV*SOL. Quote
AbiD Posted August 27, 2020 Author Report Posted August 27, 2020 Hi, Thank you for the reply.Its worked  .One more question,If the roof area is capable to hold more than 10000 panels means how we can do the calculation in PVsol?  Regards Quote
