Cezary Posted August 10, 2020 Report Posted August 10, 2020 Hi, I have problem with microinverters. PVSOl is not generating any pdf and any data. Maybe I need to change something in program options. Thanks for help.  Quote
developer_mh Posted August 10, 2020 Report Posted August 10, 2020 Hi Cezary, could you provide more detail about what exactly happens? Also, it would be helpful if you could send us your program log files. You can find them at C:\ProgramData\Valentin EnergieSoftware\log If you have a project file that you could send me via private message, it would be even easier to identify the problem. Thanks ans kind regards, Martin Quote
developer_mh Posted August 12, 2020 Report Posted August 12, 2020 Dear Cezary, thanks a lot for the project file. I had a look into it and found a bug, unfortunately. It is not related to Hoymiles inverters specifically, but with this specific configuration that i sused in your project. The bug will be fixed with the next release after the upcoming release PV*SOL premium 2020 R9 (it is on the way to be published already, so it is too late for the bugfix, I am afraid). I will send a modified project file in a private message to you so that you can simulate it. There I modified the configuration a bit as you will see, just to avoid this specfic bug. Hope that helps, kind regards, Martin Quote
