Rodrigo Posted March 12, 2020 Report Posted March 12, 2020 Hello, Does anyone have a tutorial to implement a solar park? I have seen lot of tutorials, but they are all to small buldings. Thank you Quote
developer_mh Posted March 12, 2020 Report Posted March 12, 2020 Hi Rodrigo, a solar park can be easily designed with the module mounting feature in the 3D environment. There you define the mounting system, which modules to take, row distance etc: If you need further help, please don't hesitate to ask. Kind regards, Martin Quote
Rodrigo Posted March 13, 2020 Author Report Posted March 13, 2020 Thanks for the help, But it's possible to import the terrain from google map? I've tried and the terrain its to big to import Thank you Quote
developer_mh Posted March 13, 2020 Report Posted March 13, 2020 yes, at the moment the map import is limited to 800m width and height. You can see if you are within these limits when you choose your map section: If the numbers are red, it is not possible to select the map section because the dimensions are too large. If you need to simulate bigger PV plants, I would recommend to use the normal "2D" way of planning. Kind regards, Martin Quote
Rodrigo Posted March 13, 2020 Author Report Posted March 13, 2020 Thank you It was that the problema. The map dimension is larger than 800m. I'm will try using the 2D way of planning Quote
