Modelling of an Arch
Any advice to model a steel lattice arch/truss that spans across a roof, similar to the long-span arches commonly used on football stadium roofs? - or an option to provide an accurate shading estimate of a translucent object?
Hello,
This example project features a barrel roof where the curvature is modeled by using multiple roof levels:
Alternatively, the curvature could be achieved through various mounting systems with differing inclinations and heights above ground. You can also import a 3D model of your building.
Unfortunately, it is not possible to model the partial transparency of a steel structure as a shading object in PV*SOL. (The only shading objects for which you can define a transmission factor are trees.) You may be able to estimate the shading effect by running two simulations: one without any shading, and another that includes a shading object with total (100%) shading. You could consider modeling the steel structure as a parapet.
