adding OND files for Batteries
Hello there, hope you are doing well
kindly, I suggest to add an option for the system type to be usable for stand alone PV system (off-grid or hybrid type). or at least add options to use common inverters for PV and batteries.
HV batteries from Deye or other manufacturers for example for C&I projects. For now there is no options to use HV inverters with their own compatible batteries.
Hello,
Unfortunately, it is not possible to import battery dataset files in the *.btr format from PVSyst. We have forwarded your request to our development department.
If you find that any battery systems are missing from the database, please let us know the exact product name or send us the data sheet. We will then contact the manufacturer and ask them to add the missing products.
