6 hours ago6 hr comment_21784 HOLA, ME GUSTARÍA QUE ME ACLARARAIS COMO CALCULA PVSOL LAS PERDIDAS POR CARGA Y DESCARGA EN UN SISTEMA CONECTADO A RED CON BATERÍAS. SE PUEDEN CAMBIAR PARAMETROS DE CONFIGURACIÓN EN PVSOL PREMIUM PARA QUE ESTAS PERDIDAS SEAN LAS MENORES POSIBLES? Report
5 hours ago5 hr comment_21786 Hello,Thank you for your inquiry.Our FAQs explain how charging/discharging losses and battery losses are calculated in PV*SOL.You can adjust database entries by copying an entry and saving it as a new one. In the newly saved record, you can make changes and adjust the losses accordingly. Report
