Michal Bursik Posted July 29, 2019 Report Posted July 29, 2019 Hello there, i have got problem with SolarEdge inverter. Basically If I try use any SolarEdge invertor for any project not working. Always show me "No suitable inverter configuration could be calculated...."So if I doing the same project on SolarEdge Designer,everything working.All data from SolarEdge put manually to the PVsol and its ok.My question is ,why not working automatic? Quote
developer_mm Posted August 2, 2019 Report Posted August 2, 2019 Hello Michal Bursik, We do not support automatic inverter configuration with SolarEdge inverters. Our automatic configuration does not support configurations with power optimizers, and since SolarEdge inverters are generally used in combination with power optimizers, we do not automatically configure these inverters. Kind regards, Marcel Quote
