Jon Posted July 21, 2019 Report Posted July 21, 2019 Good afternoon, I wonder if there is a way to use a map selection or a coverable object bigger than 666mx300m. I know that you can always make a simulation of the real area in different parts but in some projects in which there are different separated buildings that occupy a wide area as farms complex it would be very usefull, I am thinking also in medium module mounting/solar farms. If currently is not possible I think that would be a very good improvement for future releases. Thanks for your attention. Kind regards Quote
developer_mm Posted July 26, 2019 Report Posted July 26, 2019 Hello Jon, Unfortunately, that's not possible. The size of the objects is limited due to the usable map space and cannot be extended. But I put your wish on the wish list. Kind regards, Marcel Quote
