I don´t have all the values needed to add new invertes, paneles and batteries
Good afternoon,
I am trying to add new modules, inverters and pannels to my database, but on the mayority of data sheets from products I dont get all the specifications that PV sol asks me of.
I add an example image. How would you fill up the data of the following inverter and batteries.
https://oss.tcldigitalpower.com/1/file/2026/03/20260325092044182_6fyaq0tx4csr.pdf
Dear Alberto Perez,
If you are missing datasets, the best approach is to email hotline@valentin-software.com with the exact model designation or the datasheet. We will then contact the manufacturer and request that the missing products be added.
You can create datasets yourself, subject to the following limitations:
  • Data on low-light performance is usually unavailable for PV modules. You can either select the "Standard low-light performance" option or copy the low-light performance data from a similar module.
  • Efficiency curves are usually unavailable for inverters, so you must copy the efficiency curve from a similar inverter.
  • For battery systems, ensure that the lower value is always used when there are differing charge/discharge power ratings for the inverter and the storage unit.
Custom datasets can be imported; supported formats are PAN for PV modules and OND for inverters.
