Gigmolike Posted yesterday at 10:36 PM Report Posted yesterday at 10:36 PM Hello, I am working on a project in PVsol Premium where I need to model two buildings connected in an L-shape. I have a base plan imported from AutoCAD, and I manually draw the roof outlines on top of it using the drawing tool (pencil). However, PVsol always assigns a flat roof to my drawn shapes, regardless of how I draw them. I tried selecting the outline first and then adding a polygon edge (as suggested in some guides) to help PVsol recognize it as a pitched/multi-slope roof, but it still results in a flat roof. My main issues are: How can I draw two separate buildings and connect them so they appear as one L-shaped structure with a continuous pitched roof? How can I make PVsol recognize my hand-drawn roof outline as a pitched roof (gable or hip) instead of always defaulting to a flat roof? I have attached images showing: The roof type I want to achieve (two buildings connected in L-shape with a continuous pitched/tiled roof and solar panels placed on it) What I currently get (two separate buildings with flat roofs that do not connect properly, with a visible wall gap at the junction) I am importing the site plan from AutoCAD as a background reference and drawing the building footprints manually on top of it. I have also included image links below to better illustrate the issue and the desired result: This is what I got - current result in PVsol: This is what I tried to draw manually - my attempt: This is what I need - the desired result (these two images show exactly what I am trying to achieve): Any help or step-by-step guidance would be greatly appreciated. Thank you! Quote
hotline_oh Posted 11 hours ago Report Posted 11 hours ago Hello, Thank you for your inquiry. To create this L-shaped building, draw several polygons and extrude the buildings one after the other. You deactivate the collision (right-click on the roof) and move the buildings towards or into each other. The polygons must be rectangular so that PV*SOL recognizes them as a gable or hipped roof: This tutorial explains how to draw an L-shaped building. To watch the tutorial in English, you can select the "English" audio track in the YouTube settings. Quote
Gigmolike Posted 10 hours ago Author Report Posted 10 hours ago I was able to get the correct roof on the second part of the sketch right away — the program recognized it properly. However, on the part we are discussing here, it still does not work. No matter what I try, I only get a flat roof. I am attaching the whole project and some screenshots. If possible, could you please tell me where exactly I should mark it and how to set it correctly? Thank you very much for the quick response, I really appreciate it. Quote
hotline_oh Posted 9 hours ago Report Posted 9 hours ago Hello, Thank you for your message. Please delete the fifth point of the polygon. The rectangular polygon may only consist of four points. Quote
