On the "Presentation" page, you can export the simulation results using the "Time Series (CSV)" button. Select the desired meteorological data series, and the radiation data in kWh/m² and the outside temperature in °C will be output to a CSV file:
On the "Results" page, you can display the same data series for different time intervals in a diagram using the diagram editor:
Question
0 answers to this question
