Andy Mallett Posted June 13, 2019 Report Posted June 13, 2019 Hi PV *Sol Please can you check the data on the following panel Canadian Solar Inc. CS3U-355P The MPP Voltage is stating 28.3, but the data sheet is stating 39.4 Please can you confirm which one is correct Thank you for your help in advance Quote
developer_mm Posted June 14, 2019 Report Posted June 14, 2019 Hello Andy Mallett, which PV*SOL version do you use? The mpp voltage of the PV module in the latest PVSOL version is correct. Kind regards, Marcel Quote
