There is a huge difference in losses between charging and discharging
"Hello, I have a question regarding the following. I have designed two nearly identical systems in PVSOL. Both have 4.4 kWp of PV capacity, the same battery type with 19.2 kWh storage, and both use a hybrid inverter: a Growatt SPH3600TL BL-UP and a Solis S6-EH1P3.6K-L-PLUS. There is such a large difference in battery losses that I don’t understand the cause. Who can help me? I am uploading a spreadsheet with all PVSOL input values for the battery, the PV inverter, and the battery system. With the Growatt configuration, the loss is 819 kWh/year, while for the Solis, it is only 233 kWh/year."
Growatt
Solis
I hope someone can help me out on this.
Many thx
Kind regards
Data Solis and Growatt PV Inverter - battery system and battery.xlsx
  • Johan van t Wout changed the title to There is a huge difference in losses between charging and discharging
Dear Johan van t Wout,
Thank you for sending us the project files.
The reason for the discrepancy is the different efficiency curves of the hybrid inverters. The Ginlong Solis has a slightly higher efficiency, especially in the partial load range.
