Dutch Energy Group Posted November 25, 2025 Report Posted November 25, 2025 We have a lot of customers with a grid power limit, it would be more than welcome to put a grid limit into PV Sol. So the delivery of solar is often 0KW and the grid connection is limited to 125 kW for example. When we install more solar and a battery system also connected to a heatpump, it would be great to have a power limit, so the solar power will charge the battery at that limit or feed the heat pump and so on. Like to hear the possibilities about grid limits. Quote
developer_mh Posted November 27, 2025 Report Posted November 27, 2025 Hi Dutch Energy Group, I guess you mean a limit for feeding energy into the grid? You can enter this in the options of the AC mains, we call it the maximum feed-in power clipping: The energy management is as described here: https://help.valentin-software.com/pvsol/en/calculation/battery-systems/#energy-management That means that right now, there is no specific option to wait for the solar power to reach the feed-in limit and only then charge the batteries. But we definitely have that on our plan, along with other interesting options that you have with battery systems. Or did you refer to limits for the power that is drawn from the grid? Hope that helps, best regards, Martin Quote
