J. Esteban Posted October 8 Report Posted October 8 Good morning, Can you request that this photovoltaic module be added to the pvsol database? It would be helpful to have it in order to optimize the time spent entering data manually. I have attached the technical specifications for the solar panel. I look forward to hearing from you. Kind regards. LR8-66HVD 640-665M (30-30&15框)- Scientist-BGV01 20250605- EN .pdf Quote
hotline_oh Posted October 9 Report Posted October 9 Dear J. Esteban, Thank you for your inquiry and for sharing the datasheet. We will contact the manufacturer and ask them to add the missing products. 1 Quote
J. Esteban Posted October 27 Author Report Posted October 27 On 10/9/2025 at 6:36 AM, hotline_oh said: Dear J. Esteban, Thank you for your inquiry and for sharing the datasheet. We will contact the manufacturer and ask them to add the missing products. Dear all, Is there any update on the inclusion of this photovoltaic module in the PV*Sol database? I look forward to your comments. Best regards. Quote
hotline_oh Posted October 30 Report Posted October 30 Dear J. Esteban, Thank you for your inquiry. We contacted the manufacturer, and new products have been added, but not the ones you requested. We will follow up again. You have the option of creating the module data sets yourself. The best way is to copy the data set of a similar module and use the parameters from the datasheet. Since the U/I values for low light behavior are not listed on the datasheet, you should select the standard low-light behavior or use the low-light behavior of a similar module. 1 Quote
