Gordana Posted October 5, 2025 Report Posted October 5, 2025 Hello, I have a question about inclination. In documentation, there is said that inclination is 57 degrees and I do not understand how is that possible. I have made open space ground mounted solar power plant. Inclination of terrain is 27.4 degrees, and tilt angle of solar panels is 30 degrees because that is optimal for our geographical location. Did Pv sol maybe summerize these two inclinations and if answere is yes is it correct to do so? Thanks in advance Gordana Quote
hotline_oh Posted October 6, 2025 Report Posted October 6, 2025 Dear Gordana, Thank you for your inquiry. Yes, in PV*SOL both inclinations are added together. If your open space location already has an inclination of 27 degrees, your mounting system only needs an inclination of 3 degrees. 1 Quote
