J. Esteban
Everything posted by J. Esteban
  1. Good morning, I would like to enquire whether it is possible to improve the rendering quality in PV*Sol so that the modules remain clear when the image is zoomed out. At present, they appear as dark blocks and only become sharp when I zoom in. I have attached a few reference images for your review. Thank you in advance for your assistance. Kind regards. J. Esteban
  2. Dear all, I kindly request your urgent assistance with the following requirement, which must be submitted to the electricity distribution company: “Hourly generation forecast curves: Please provide the projected generation curves with hourly resolution, considering a sunny day scenario [kW] vs [h] – Excel format.” I look forward to your comments. Kind regards, J Esteban
  3. Good morning, Thank you for the information provided. I will use the shared database as a reference and update the incorrect values that had been entered manually. Many thanks for your support! Kind regards.
  4. Dear PV*SOL Team, Good afternoon. I would appreciate your assistance in updating the data for the SMA Core1 62US inverter in your database, as the current version appears to be outdated (possibly from 2018). I attempted to enter the inverter data manually; however, the system does not allow automatic configuration or connection options with the parameters provided. This may be due to an issue with the existing database entry. Please find attached the inverter datasheet for your review and update. I have also attached a technical datasheet for LONGi solar modules for your consideration and potential inclusion in the software. Thank you in advance for your support. Kind regards. STPCORE1-DS-en-34.pdf Longi LR8.pdf
  5. Dear all, Thank you for your assistance. I will await your confirmation. Kind regards.
  6. Good afternoon, I hope you are well. Would it be possible to obtain or generate the DWG drawings showing the electrical connections per inverter only, rather than as a combined layout based on the overall plan or PV*Sol configuration? I look forward to your comments. Kind regards.
  7. Good morning, After reading your suggestions that the cabling can only be routed over surfaces, I wanted to check something with you. Does this mean I also wouldn’t be able to obtain the estimated solar cable length if I run a ground-mounted layout with module supports? I’d appreciate any guidance you can offer. I’ve attached an image showing how I currently have the design set up. Kind regards.
  8. Hello! Thank you very much for the clarification! Could you please let me know exactly where I can find the Production Forecast? Or how to display it as a bar chart? Kind regards.
  9. Good morning, I would like to check whether it is possible to obtain the following curves in PV*SOL and, if so, in which section of the software they can be found: The projected daily generation curve with hourly resolution (for a typical sunny day and a typical cloudy day). The projected annual generation curve with monthly resolution. I look forward to your response. Kind regards.
  10. Good morning, I will be sending the simulations by email shortly for your review; I’ll provide further details in the message. I appreciate your assistance in advance. Kind regards.
  11. Good afternoon, Would it be possible for me to send you the final project design so that you could perhaps provide some guidance on how to prepare the cabling layout, please? At the moment, I’m considering carrying out the cabling separately for each roof inclination — that is, one layout per roof face. This would of course require selecting different types of inverters to enable the automatic cabling configuration, according to the capacity of each roof slope. From there, I could develop a more detailed cabling plan. I mention this because I will soon have the solar cable reels in stock, and I need to quantify the amount required specifically for this project. Thank you in advance for your assistance. I look forward to your comments. Kind regards
  12. Good morning everyone, Is it possible to update the reference satellite image used for the 3D layout after I’ve already created a 3D design? If so, where can I find this option? Or would I need to start the design from scratch and select the satellite image again? Kind regards.
  13. Dear all, Is there any update on the inclusion of this photovoltaic module in the PV*Sol database? I look forward to your comments. Best regards.
  14. Good morning, Can you request that this photovoltaic module be added to the pvsol database? It would be helpful to have it in order to optimize the time spent entering data manually. I have attached the technical specifications for the solar panel. I look forward to hearing from you. Kind regards. LR8-66HVD 640-665M (30-30&15框)- Scientist-BGV01 20250605- EN .pdf
  15. Dear Sirs, Thank you for your recommendation. I've followed those steps and the issue of having separate systems has improved. I have another question. Is there a way for the programme to determine the amount of DC cabling from the strings to the inverter? Is it possible to establish a reference point for where the inverters are located and then indicate which MPPTs they would be connected to? I would need information on the estimated amount of DC cable I'll use in order to quantify the total length required. I look forward to your prompt response.
  16. Good morning, Now that the first point has been clarified, just yesterday I discovered that “trick” for fixing connections in multiple areas. Regarding the second point, it's great that connections can be made that way! I'll try it again, making the connection that way and changing the names of the surfaces. I think it will be easier to modify connections by system so that there is not just one and to prevent all connections from being activated at the same time. I will share the project with you by email. I have not yet completed the connections as I am still defining them to minimise losses due to voltage drops. Thank you very much for your help!
  17. Good morning, I am having problems connecting modules. I'm designing a 1.42 MWp photovoltaic plant, I am in the connection stage, and I have noticed the following issues: 1.- As you can see in the first image, I have used some surfaces to use panels from other areas in order to fully utilise the inverter's MPPT. Perhaps because it is a large system, the wiring plan options where I can use groupings, cable glands, etc. no longer appear, as shown in the second image. Why is this? I would like to place these items and have a breakdown of how much cable I am estimated to use, as shown in the third image 2.- The next new feature concerns the connection of photovoltaic modules. As you can see in the fourth and fifth image, I have used solar panels on both sides of a building, leaving the connection provided by the programme by default when I have two sides. However, if I try to modify that connection and go to the wiring plan, the programme completely distorts the connection and pretends that it is not using the panels on the other side of the building, as you can see in the sixth and seventh image. So I have made a connection that is not as viable as in the eighth image because of the error that appears, since if I modify the module connections when I use multiple areas, the connection is distorted; even those panels appear without a connection. I would appreciate any support that would help me resolve these issues. I look forward to your comments. Thank you.
