Go green BG
Go green BG's Achievements
Explorer
Explorer (4/14)
  1. Hello again! I need help. The construction of today's project is tracker. The axis along which it moves is east-west. Starts at 55 degrees and stops at -55 degrees. I am attaching a photo. How do I set the parameters correctly in a 2d design to calculate system performance? Rotation Axis Incline - ? Rotational Angle of Opening - ?
  2. Is there already an option for tracker construction in 3d?
  3. Do I collect the projects outside of the pv sol program or is there a way to make it happen within it?
  4. I am preparing a project where the construction of the panels can change its slope. This happens mechanically two or three times a year. How can I give an annual production forecast when the slope is 15 degrees in one part of the year and 45 in the other? Thanks in advance!
  5. Hi, Martin 1. I was hoping for more, but that's kind of an option too. 2. I specified Standart and Spec. Annual Yield fell by nearly 1,000 units compared to the one-faced ones, which is certainly not the real performance. And how can I delete the versions of the panel that I created, because the program does not allow me to specify which version to use, but makes every correction - the next version. Can you prepare a workshop for the introduction of panels by characteristic from a manufacturer. It would be very helpful! 3. I don't want to see dimensions of the entire roof in the presentation, but only of the panel. Is it possible to add them to the Parts List automatically along with the brand?
  6. AS-8M132-BHC Bifacial Half-cell Module Specification.pdf
  7. 1. How can I see the parameters of the created systems without removing the panels already placed in the project? 2. "My Solar AS-8M132-BHC-665W" panels are missing from the database. I made a copy of another bifacial panel of the same manufacturer, but I don't know which parameters to enter in the irradiance field. I am attaching a technical specification and a screenshot. 3. Is it possible to have the dimensions and characteristics of the placed panels in the presentation? Thank you in advance
  8. I am trying to stake this type of tracker (from the picture). Is it possible for pv sol to arrange the panels on a property with set dimensions? And again I ask: is there a video tutorial for a 2D project with trackers?
  9. Hello again! I'm trying a tracking system on the ground. How do I set the dimensions of an irregularly shaped property and the distance from its boundaries? Is there a video tutorial for a project with trackers? Thanks in advance!
  10. Hi! Where is the menu from the screenshot? I want to do a project with Amerisolar AS-7M144-BHC, but there is only AS-7m144-HC in the library, and it is not bifacial. Can I make a copy of this module and adjust its parameters so that the program reports in the results that the model is two-faced?
  11. I have a problem moving the pv sol license. I disabled registration on the old device, but I can't register on the new one. I wrote to sales@valentin-software.com, but still no answer, and I need the program today.
  12. It works! Thank you!
  13. Another building - same problem. How can I specify two surfaces to connect in one MPP?
