SunSynk Inverter Registering Incorrect Useable Battery Energy C10
Trying to simulate a home system on 3D and when I select the SUN-5K-SG01HP3-EU-AM2 Inverter the Useable Battery Energy C10 is showing as 50.7kWh so I don't know if it is being registered as a full rack. For reference a similar Deye 5k inverter is showing a Usable Battery C10 of 5.5kWh. On further inspection all the SunSync inverters from 5k to 25k all have a Useable Battery C10 of 50.7 kWh.
Dear Alphagen,
Hybrid inverters can usually be combined with a variety of battery sizes. The manufacturers who enter their products in our database often do not enter all possible combinations. Which battery size (battery capacity) would you like to use together with the SUN-5K-SG01HP3-EU-AM2? We can contact the manufacturer and ask for an update.
Alternatively, you have the option of creating a missing battery system yourself. We recommend that you copy an existing database entry (right mouse button --> Copy), make the desired changes and save the data record under a new name.
