Heizen Posted February 27, 2025 Report Posted February 27, 2025 It seems, that only parallel buffer storages are avaliable and not buffer storages in line. Is there a special reason? Quote
hotline_oh Posted March 5, 2025 Report Posted March 5, 2025 (edited) . Edited March 10, 2025 by hotline_oh wrong answer Quote
Heizen Posted March 9, 2025 Author Report Posted March 9, 2025 Sorry, probably due to my inadequate knowledge of English there has been a misunderstanding. I did not mean electrical storage but water storage in a heat pump system. Here I only saw the possibility of installing the storage in parallel as a hydraulic separator, which leads to efficiency losses. Installed in series, it can also provide the necessary defrosting energy and extend the running times, but as far as I know it has fewer losses. Quote
hotline_oh Posted March 13, 2025 Report Posted March 13, 2025 Dear Heizen, Thank you for your inquiry. Unfortunately, systems with buffer storages connected in series are not available in GeoT*SOL. Systems with buffer storages connected in series can be simulated in T*SOL. Heat pumps can also be selected. However, the heat pumps are not simulated, but treated like boilers, i.e. the heat pumps have an output that they can always deliver. Quote
