December 13, 20241 yr comment_18186 Hi, Can you tell me if there is a way I can export the shading loss % per array as an annual figure? Thanks Report
December 18, 20241 yr comment_18211 Hi CarlSEL, Thank you for your question. Unfortunately, I have not yet understood exactly what losses you mean. Do you mean the reduction in yield due to shading, as we indicate on the results page under Simulation > PV system for the entire system, but broken down for each module area? Under 'PV System Energy Balance Balance' > 'Configuration', we also specify the module-specific partial shading for each inverter and MPP tracker. Does this information help you? Or do you mean the solar radiation losses per module area? Hope this helps you to get closer to the answer. Kind regards Mikio Report
January 9, 20251 yr Author comment_18367 Hi, Yes I think maybe 'Under 'PV System Energy Balance Balance' > 'Configuration', we also specify the module-specific partial shading for each inverter and MPP tracker. Does this information help you?' is what I am looking for. Thanks Report
