ionut Posted January 10, 2024 Report Posted January 10, 2024 Hello, Please help in an on-grid photovoltaic system, how can I allocate parallel batteries to each inverter? I found the option to allocate to only one inverter in the system and I want to allocate for 2 inverters and 1 inverter without battery thank you Quote
developer_mo Posted January 15, 2024 Report Posted January 15, 2024 Hello ionut, thanks for your post. I'm unsure if I got your question right. Just to clarify, is this the configuration you are looking for? (please see attached circuit diagram) If so, you can achieve this with two battery system groups (this feature is available since version PV*SOL 2024 R1). First ensure that your battery systems coupling type is "DC intermediate circuit coupling". The type of coupling can be checked in the "Type of Coupling" column or via the "Info" button in the database dialog of the battery system under "Type of Coupling". Then you can copy the existing battery system group and set the connection to the inverter to the second inverter in the copied group. Please feel free to reach out if that doesn't answer your question. Kind regards Mikio Quote
ionut Posted January 20, 2024 Author Report Posted January 20, 2024 Yes, I solved this problem by updating to the pv sol 2024 version. Thanks for the quick reply But now I have the problem of missing battery from Huawei LUNA2000 - 97KWH-1H1. How could I solve this situation? thank you Quote
developer_mo Posted January 22, 2024 Report Posted January 22, 2024 Hi ionut, thanks for your report. I'm glad it worked. I forwarded your request to our database team. They will contact Huawei to add the battery to our database. In the meantime you can add the missing battery to your user-bound database like following: 1. (in the 2D part of PV*SOL) on the top right menu click on "Databases" > "Batteries" 2. in the left "Look Up" filter for companies, search for Huawei and click on it 3. in the right panel under "Actions" click on "New" 4. add the missing product according the datasheet and click on save You can now use your created database entry as usual. For further information please have a look at our according online help: https://help.valentin-software.com/pvsol/en/databases/components/batteries/ Kind regards Mikio Quote
