switching between 2D and 3D
Hi, I have changed from the standard PV Sol to PV Sol Premium. Everything runs fine so far. I have already created successfully my first 3D projects. Anyhow, is there a button or anything to switch between the modes? Or do I always have to go through options, chose a starting mode for next session and restart the program?
For fast checking of inverter configurations I mainly use the simpler 2D version. For complicated projects I use the 3D version. Switching between those two is kind of tricky.
Hi E-pn
you don't have to restart the program, it is possible to toggle 2d/3d under system type, climate and grid.
It will delete your 2d design  (because it asks yout to define the 3D design) however your climate data settings and such will be kept.
I would recommend to make an extra backup before switching.
Hope it helps,
Best wishes,
Hi there,
in System Type, Climate and Grid you can switch between 2D and 3D.
(Type of Design : Use 3D Design). I hope this is helpful.
Yours sincerely
Sam
