hotline_sf Posted October 29, 2014 Report Posted October 29, 2014 How to enter a new heat pump into GeoT*SOL?
0 hotline_tm Posted October 29, 2014 Report Posted October 29, 2014 Open the heat pump database via the menu item "Database" > "Heat pumps". Now select from the available records a heat pump of the same type with a comparable coefficient of performance (COP) and click with the right mouse button on it. Select from the context menu "Create copy". In the definition window you can enter the model type of the heat pump under product. Enter the required characteristics according to the data sheet. If you do not find all the test points on your data sheet you only have to change the test points which are available and leave the other according to the template. Save everything with "OK".
Question
hotline_sf
1 answer to this question
