Pvsol 2016 - Inverter Numbers
Hello,
depending on the defined configuration limits, the characteristics of the selected modules and inverters the program always tries to find a configuration with the minimum possible inverter number.
You are also abel to define or overwrite the configuration manually.
Best regards
Your Technical Support
