December 9, 201510 yr comment_672 Hi guys, I´ve a question about the info in the Configuration Check window. If you see the next image, there is a U0 = 1024,3 V above the maximum level, but the temperature for that U0 is -283°C..., is that correct??? Regards, Boris. Report
December 15, 201510 yr comment_673 Hello Boris, No, the temperature was not correct. It was a mix of a °C temperatur minus the 273 K. This was totally wrong. We have solved this with the last update. Now the program show the right temperatures. Best regards Your Technical Support Report
