  • 0
What Is A Pv Sub-Array?
hotline_sf
Question
1 answer to this question
  • 0
A PV array/sub-array is a PV surface unit made up of the same types of module mounted together and set at the same angle and orientation. If you have a number of inverters connected to an array, these also have to be all the same type and configured in the same way.
You are able to define up to 6 sub-arrays in PV*SOL Pro/Expert. In PV*SOL premium and PV*SOL the number of sub-arrays is arbitrary.
Link to comment
Share on other sites
