VladimĂr Brezáni Posted January 15, 2022 Report Posted January 15, 2022 Hello, after finishing the project, is it possible if we want to keep everything only we want to change the location in google maps? because in this case we will have to start over again. Thanks a lot! Quote
VladimĂr Brezáni Posted January 15, 2022 Author Report Posted January 15, 2022 Another question that is related to the previous one How can I export buildings from an existing project to a new project? Thanks Quote
Jimmy Posted January 17, 2022 Report Posted January 17, 2022 Hi VladimĂr, The Google maps location is basically just a screenshot of the map that is used as a texture for the ground. You can take your own screenshot and replace the texture to make it appear as a new location. Getting the scale 100% correct might prove a challenge though. Regarding your second question. If you've made the building in PV*SOL it isn't possible to export the building. If you plan to use the same building in many different projects it might be better to design the building in another 3D modelling software (like SketchUp) and import that building to each project. Best regards Jimmy 1 Quote
