November 30, 20214 yr comment_6340 Hello. I wanted to import an object from Solidworks into PVSOL. As the only compatible format was STL, I went with that. The issue is that the final import is totally white with no way to change the individual textures. Is there any way to fix this that I am missing? Thank you in advance for any replies. Radek. Report
December 1, 20214 yr comment_6342 Hi Radek, The textures in PVSOL are limited to 1024x1024 and PVSOL can only read texture names with a-z and 0-9 characters in the name. So you probably need to change the texture size and possibly rename the file for it to work. Report
