Franco Posted May 28, 2021 Report Posted May 28, 2021 Hi, I'm doing my thesis in geology about modeling temperature and alteration mineral assemblage using geothermal fluid chemical data of a geothermal system. I have data about concentrations of aqueous and gaseous species, pH, and stwf - cfact estimation, among other things. I'm using the synthetic water reaction at 250 °C of test problems V2.1 examples as a template. I'm not sure about the convenience of using this input file like this. In the other hand, when applying the "GeoT2.1-PC64.exe" executable, the windows terminal tells me the next: Start reading inputs.... Execution aborted - stop Press any key to end..... I'm need some help. I'm consider myself a beginner in using this software. Regards, Franco Galarce A. Quote
developer_ur Posted May 31, 2021 Report Posted May 31, 2021 Dear Franco, you got in the wrong forum. Our program GeoT*SOL is for simulating heat pump systems for domestic hot water and heating. Kind regards Quote
Franco Posted June 3, 2021 Author Report Posted June 3, 2021 Where can I ask these questions? If you could provide me with a link, I would appreciate it. Regards Quote
developer_ur Posted June 4, 2021 Report Posted June 4, 2021 Sorry, I can't provide you a link because you're using a program that is not from our company. Kind segards Quote
