Using the example of a vent that shades two modules (with >1%):
First, define a separate module area for the two shaded modules.
Ensure that PV modules can be selected individually.
Select both modules and right-click to choose "Add to 'Define Module Areas' dialog."
Click "Define Module Areas for Configuration."
In the "Define Module Areas" dialog:
Rename the module area to "Roof Area South - shaded."
Import all other modules and rename them to "Roof Area South - not shaded."
Click "Configure."
Next, in the inverter configuration window, select both module areas and choose "Configure module areas together":
Now select the desired inverter, choose the polystring configuration (for one of the four MPP trackers), check the box for "Power optimizers," and assign the two module areas as follows:
The two modules with optimizers are then correctly assigned in the string diagram:
Question
0 answers to this question
