Question
The module tilt and orientation are influenced by two factors: the tilt of the mounting system and the pitch of the roof. Together, these two tilts determine the resulting module tilt and orientation.
This can be visualized as follows:
If you were to place a ball on the module surface, it would not roll exactly in the direction of the mounting system due to the two tilts, but would instead roll in the direction of the roof pitch. This is the resulting module orientation. The steeper the roof pitch, the greater the deviation of the resulting module orientation from the orientation of the mounting system. For example, if you have a mounting system facing south on a west-facing roof, the ball will not roll south, but southwest.
0 answers to this question
