How do I plan a stand-alone system?
On the "System Type, Climate and Grid" page, you can select the "Stand-alone PV System" (with and without a backup generator) system type. Planning stand-alone systems in PV*SOL is based on the SMA Off-Grid Configurator program, which we originally developed for SMA. This program contains the design rules that SMA has specified for us. These rules cannot be changed or deactivated. For example, only systems with AC-coupled battery systems can be planned; DC systems are unfortunately not possible. We understand that these rules may not necessarily apply to other manufacturers and may entail further limitations.
For greater flexibility in component selection and improved transparency during the planning process, we recommend that you initially plan your stand-alone system as if it were a grid-connected system:
  1. On the "System Type, Climate and Grid" page, select a grid-connected system.
  2. Set the feed-in limit to zero; then no energy will be fed into the grid:
  3. The value under "Total consumption covered by grid" indicates the energy that cannot be covered by the PV system. This energy must be provided by the backup generator or (if you are not planning on a backup generator) "approach zero".
