Anders
Anders's Achievements
Explorer
Explorer (4/14)
  • Dedicated Rare
  1. Anders
    L shape house
    Hello Can you help me with my 3D project. I want to draw the house in 3D. I don’t know how to draw the house with the angled extension where the roofs intersect. can you explain? Karin og Bent.pvprj
  2. Anders
    Module picture
    okay, thank you
  3. Anders
    Module picture
    Hello I know how to change the image on the project overview page. But how do you change it on the module surfaces page so i can see all the PV moduls? I would still like to keep south pointing downward, so that it is not rotated like the overview image. Thanks. Dagrofa Herning.pvprj
  4. Anders
    Shadows
    Hi again. I’ve figured it out now. I checked the “medium” option. I’ve now created the project with the Google API. The report says it’s only 0.1% reduction in yield due to shading. Can that be correct? Have I created the project in 3D correctly? Dagrofa Horsens - Kopi.pvprj
  5. Anders
    Shadows
    Okay. thank you. I have now got a API key. But I get this error when i try to download orthophoto. Why?
  6. Anders
    Shadows
    Hello I have several projects for which I need to run some simulations—in 3D. I want to make them as realistic as possible. I have modeled the buildings in 3D. I would like it if one could set the shadow effect, for example, to 2%, but of course, that isn’t possible in 3D. Therefore, I am asking for your help in creating a shadow effect. I am attaching two of my projects here. How do you assess whether shadows should be taken into account? I know that one can model a tree to simulate shadows, but do you find it necessary to include a shadow effect for my projects? Thank you. Dagrofa Horsens.pvprj Dagrofa Hjørring.pvprj
  7. Anders
    3D
    Okay. Thanks. I will like to simulate the shadows. On the roof, there is some technical equipment that I would like to model in 3D in order to see its shadows. I have tried to draw a polygon to illustrate the technical equipment, but I get an error as you can see in the attached image. How is this done? It is a bit of a tricky building I think, so how many panels can you fit on the building? Are there any shading conditions I should take into account in the simulation? surroundings Dagrofa servicekontor new.pvprj
  8. Hello. Can I change the headline and the image on a compact report? I would like to change the headline “Dit PV-system.”
  9. Can I change the headline and the image on a compact report? I would like to change the headline “Your PV system.”
  10. Anders
    3D
    Hello I am still new to PV SOL and now I have to simulate PV on a big Building in 3D for a customer. I don’t know how to do it, since the building is a square with a “hole” in the middle. Can you help with the 3D model of the building? Thank you Dagrofa servicekontor.pvprj
  11. I would also like to now if I can change the picture on the front page in the compact rapport?
  12. Hello. I want to change the headline in the compact customers presentation. For now it says "Dit PV system" How do I do that?
  13. Anders
    2 question
    I would like to connect the two roof surfaces to the same inverter. Module Array 01 and 02 to the same inverter. How do I do that? And my next question is about the DC cable going out to the panels. When I enter a length of, for example, 30 m, how do I change it so that it is 2 × 30 m? Since there is a positive cable and a negative cable. Dagrofa Randers.pvprj
  14. Anders
    Shadows
    Thank you for your reply. Yes, I know that in 2D I can enter a shadow percentage and was hoping I would have the same option in 3D. But I’ll try adding some trees instead.
  15. Anders
    Shadows
    Hello. I have created a design in 3D. I would now like to set the shadow effect to, for example, 5%. How do I do that? Risvænget 6.pvprj
