Paul I
Everything posted by Paul I
  1. Thanks Mikio Much Appreciated response
  2. Hi there I noticed that there was an update to the SolarEdge Inverters and when I looked at the SE50K Unit - 25kW which is the new inverter from the update and the other 50K inverter I use the SE50K-EU-AUS/APAC is now no longer available for me to use. When I checked the data for the Inverter compared to the datasheet I noticed it was set for the 25kW inverter and all values were different from the datasheet from SolarEdge's website. I ran a PVSol using this inverter and when I compared it to a previous design I done of the same set up I noticed the sizing factor ended up over 268% rather than the 138% I originally had. I think this will be the same for the larger modules as I have checked the 100K inverter and it was the same issue. Could you provide a way of using these inverters to get the desired output rather than the output of just 1 unit as these inverters are made up of several units Thanks Paul Ingram
