Rene
Everything posted by Rene
  1. thank you Frederik, now i know how to create default locations.
  2. Also my question the maximum DC capacity of PV Sol about 10000pcs. Module , is there is possibility to expand more like 20000 to 30000 pcs cause our other project about 10Megawatt to 30Megawatt ? thank you in advance.
  3. hello, Good Day, I just want to ask , Why is that Iraq country is not in the choices?
  4. Hi Martin , one more thing how to change the dollars sign into Euro in the cash flow?, thanks in advance
  5. Hi Frederik Good Morning, can you explain or differ the Spec. Annual Yield, the PV Generator Energy(AC Grid) , the Own Consumption , and Grid Export for this Result , many Thanks. This is the settings that have a consumption. This is the simulation settings with PV system Going to grid .
  6. Hi Frederick, how can i Register in the manufaturer database need an Log in account? thank you for your great response
  7. Hi Frederick , the database Standard low-light performance setting cannot edit right? how can i copy or cannot
  8. Hi Frederik; Thank you for my inquiry , also the 2nd thing is this we want to register our solar modules in your Data base so that our own Modules are there, how can you do that in your part , also what is the requirement for registering our new panel in your data Base?
  9. Hi, I selected PV Module in your database which is the 700W - Bluesun Solar Co. , so this means the module is wrong, thats why the performance ratio is too big ?
  10. Hi Mr Frederik; thank you for the response
  11. Hi Good Day to everyone; I need the answer about the below Project simulation, the Maximum Capacity of both are much the same 1MWp in the 1st Simulation I used 700Watts and the 2nd I used 555Watts but why is a big difference regarding the Production yield and the Performance ratio? hoping for your explanation thank you very much.
