El_Bay
El_Bay's Achievements
  1. Hi Martin, Thanks for the quick response. I will try without shading analysis Kind Regards Eleanor
  2. Hi Martin, I have also been trying to build a DC connected system with 2x hybrid inverters and 2x batteries. I think am coming up against the same problem, where I believe the system appears to 'underperform' because both batteries are connected to 1 of the hybrid inverters rather than each battery being connected to it's own hybrid inverter. So, the charging ability is limited. I have two questions: 1. Are there plans to build in this functionality into PVSol in the near future? 2. What is the best work around to be able to model a system like this but without the limitations? I have been thinking about building as similar a system as possible (but AC connected) to approximate the simulation. However, I am aware I need to match the inverter specs and battery charging specs very well in order for it to be sufficient. Would this be an okay approach? Thanks for your help in advance, appreciate any guidance you have! Cheers Ellie
