Karina Suharevska
Karina Suharevska's Achievements
Apprentice
Apprentice (3/14)
  1. Hello! I changed table and left only kW column. It worked!
  2. I've been trying to add my own load profiles (consumption data) into PV*SOL, but I keep getting this error box saying: "Conversion error in the data line: 1." What could this mean? The file I've been trying to add is a CSV-file and the only data in the file is the consumption, in kWh. Time interval is 60 min, leading to 365 days and 8760 values. The CSV-file contains 8760 values in one column. Thankful for any help! ST paterina dati Ragana DUS 07.24-06.25_PVSol.csv
  3. EXTRA question - how can I set a ground level and slope if I want to load data file - picture.
  4. OUh, it looks like it does not work in my country - Latvia.
  5. Also when I check "Quality: HIGHbox" it does not show me a colored map.
  6. Yes, how can I solve this?
  7. Hello! I wanted to intrgrate Google Solar API, but I have error. How to resolve it? I have made a google account, have an API key. Madea project in Google console. How to resolve it?
  8. Hello! PV Sol shows me eroor message "You already have 500 objects (type Wall). The maximum number that therefore been reached". How to add panels on roof? or have to deal with this message to add extra panels?
  9. Hello! The screenshot files are incorrect. Please see screenshot below and use them for comparing. These are correct screenshots. Inclination and orientation seems the same. I have question about: 1) Low-light performance - why with 460W panels its much bigger value than for 450W panels. 2) why spec.annual yield differs? 3) DC/AC conversion differs because of changing inverters? Olimpia 9.5._1820gab.pdf Olimpia_8.9_450W.pdf
  10. Hello! I sent You both files in private messages.
  11. Hello! I made one solar plant with 1820 solar panels, each 450W. Total output 819kW with spec.annual yield 855,61 kwh/kwp. Grid feed in 700 955 kwh/year. Then I changed all 1820 panels to 460W. Then total output was 837,20kW with spec.annual yield 831,37 kwh/kwp. Grid feed in 696 232 kwh/year. My question - why the spec.annual yield and grid feed in drop off so much ? I am concerned because, the power of one module became bigger, but the spec. annual yield decreased. Please see file attached.
